I have a problem with my bath, specifically the hot water. When I turn on the hot, it will warm up to give hot water, as usual, however after a few seconds the temperature turns tepid. If I turn off the water and leave it for a few seconds, then turn it on again, I get a blast of very hot water for 4-5 seconds, then again it cools off to slightly warm. This is reproducible. Setting it to cold gives cold water. The hot and cold water supply come into a brass fixture with a diverter stem - it is a single tap control for the water. I bought the house recently and have been doing some remodelling of the bathroom. To the best of my recollection, the hot stayed hot previously, however I have not done any work at all on this section of the bathroom and so do not think that I have done anything to cause the problem. So, do I need to replace the diverter, or is there some simpler explanation and fix? Clearly I am not a plumber, but I am reasonably handy. Any advice appreciated, thanks.
