Results 1 to 5 of 5
Thread: re routing electic plumbing for washer
    Default re routing electic plumbing for washer
    Hi, does anyone know if it's possible to re rout existing plumbing for an electic washer? The plumbing works but the drain pipe is a simple black PCV pipe...the sewer/main drain is across the room and same level.
    The washer works but is in the middle of the basement that we're trying to remodel.
    Domcal
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    Yes, it's possible. Without being there, I can't say if it's probable.
    Quote Originally Posted by kordts
    Hi thanks for responding. Could a plumbing move all the plumbing over to the new location of the washer? I figure that the drain pipe would have to stay but we'd have to have a long pipe extending from the washer to the drain which is about 15 ft... is this a bad idea or is there a better alternative? The other plumbing ( hot and cold-copper pipes) seem to be less of an issue?
    Domcal
    The only problem might be the drain. A drain must be sloped at least 1/4" per foot of length, and a washer drain needs to be 2" diameter, be trapped and vented. There's nothing wrong with ABS pipe (black) if that's what the rest of your drain system is. I'd strong urge you to hire a plumbing contractor for this job, there are too many pitfalls that you might encounter. You're correct that water plumbing and electrical connections will not be difficult to deal with.
    Default washer
    Is it possible to move the washer? Yes, of course it is. Is YOUR plan the best one? Probably not, and it might be the worst one, but someone has to look at it and decide the proper way to move it.
