sorry if this is a newbie question, here goes...i am repairing a leaky joint in my copper water supply lines. i know that to drain the pipes i should shut off the water supply and open the highest and lowest faucets in the house. the leak is in the basement, which is unfinished. the lowest faucet in the house is still higher than the leaky joint. how do i drain this pipe?
i have considered opening the drain valve at the bottom of the water heater. i would rather not haul that much water out of the basement, but is this my only option? thanks for any help...
