BS
I'll be replacing the rough-in valve for my tub-shower. The hot and cold copper supply lines are 6 inches apart on center, meaning that the ends of the elbows that turn toward the valve are about 4 inches apart from each other. Between each elbow and the existing valve inlet is a little less than 1 inch of exposed copper connecting pipe which is soldered to the elbow and valve.
The problem is that the body of the new valve is also 4 inches across at its inlets. This means that the supply line elbows and valve inlets would be touching with no exposed connecting pipe between them. Sweating these joints doesn't seem possible.
I see two options:
1. When I cut the old valve out, I should be able to spread the supply lines apart a little. I think I can gain an inch or so, maybe 2 or 3 inches max. (I'll be constrained by the small tolerance in the floor plate holes the supply lines run through.)
2. Cut the supply lines below the valve and sweat on a dogleg of additional pipe to provide a wider separation at the valve. (I've had mixed success with sweating in the past, so the prospect of sweating multiple joints doesn't appeal to me. But I'll do it if I have to.)
What would you suggest? What is the minimum length of exposed connecting pipe necessary for sweating the fittings?
- Bernie
I see two options:
- Bernie
