Results 1 to 8 of 8
Thread: Hot Water heater Connections
    Default Hot Water heater Connections
    New hot water heater (GE) has female galvinised pipe fittings built flush to the surface of the tank. A galvinished pipe riser is installed so it can be piped onto a copper adapter. My question is "dosen't the two disimilar metals cause problems down the road?"' and "should pipe dope or teflon tape (or both) be used between the copper fitting and the gal pipe?"
    In the Trades GoTanklessToday's Avatar
    Jan 2007
    Renton, WA
    Quote Originally Posted by pilotboat
    Where I'm from, we use flexible copper connectors that are designed to attach to galv fittings. You must use dialectric union if you are going to run your copper water lines straight to the heater.
    http://www.hammerzone.com/archives/p...n_de/intro.htm
    And by the way, its a cold water heater, not a hot water heater. haha
    The tank should have had the nipples included. They are not galvanized, but a material that will safely make the transition to the copper flex lines. I use the old fashioned pipe compound rather than tape, but tape will work.
    Sep 2006
    Phoenix, AZ
    Quote Originally Posted by GoTanklessToday
    If you have a re-circ system, it could be considered both...LOL
    Boy am I confused... I thought it was a heater that made the cold water hot???? Or does the heater make it cold???? HELP>>> I'm going to weird out.
    Jan 2007
    Renton, WA
    Quote Originally Posted by markts30
    Touche!
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    Our area has hard water, so I remove the factory nipples and use brass.
    Default heater
    if you are going to pedantic over semantics, then it is a "cold water heater" for a couple of minutes until the water is raised one degree. Then it becomes a "warm water" heater until the water temperature increases even more. At that point it becomes a "hot water" heater until the thermostat is satisfied.
