Scott99
- Messages
- 33
- Reaction score
- 0
- Points
- 0
I was just reading an article that said you can't solder soft copper but need to use a flare or compression joint. Is that correct?
I just cut out a section that was soldered with a coupler connecting soft to rigid and was planning on doing the same thing.
I also noticed that my Autocut pipe cutter seems to crush the soft pipe a tad when using it. found on their web site that it's not to be used on soft copper. the area is too tight to use a hack saw to cut it off.
thoughts?
thoughts?
