Pipes Banging
Darcy
I have 2 problems. When the kids run off the water quickly (single push/pull lever) the pipes make a thuding/loud Banging sound. Also when 1 person is in the shower, and someone else runs the water, the pipes in the shower bang violently. I have 2 showers doing this, and they are both about 16 years old. Could the shower issues be the valve's?
Markts30
Commercial Plumber
Phoenix, AZ
What type of piping is the water supply in the house?
Sounds like unsecured lines...
KD
Install water hammer units see water hammer post.
Chassis
Engineer
SE Pennsylvania
Pipes also could be loose. I had this problem in a shower, and in the demolition/remodelling process I found that the pipes were not secured to any wood framing and were very very loose. The new piping I installed was secured to framing members and is now firmly attached.
Darcy
cooper pipes
If it is in fact unsecured pipes. Is there anything I can do without tearing holes in the walls to secure them?
NO...if the pipes are flopping around, you need to secure them.
