hifibuf
I'll be using an Oatey brass no-caulk shower drain in my bathroom project. I test fit the drain on a piece of 2" PVC to see how well it grips the pipe. I noticed when tightening the caulk ring nut that it starts to bind against the rubber caulking ring and makes it difficult to get it tight enough. Should I apply a lubricant between the no-caulk ring and the ring nut? If so, what should I use? Soap? Last question - how tight is tight enough? If it leaks it ruins my first floor ceiling.
Thanks,
Richard
Thanks,
Richard
