Results 1 to 10 of 10
Thread: passport ensemble jacuzzi tub
    Default passport ensemble jacuzzi tub
    I have a Passport Ensemble Jacuzzi tub and want to replace the brass rings and brass ball jet assembly. Any idea where I can find parts? Thanks
    Default parts
    Try looking at
    http://www.uspartscenter.com
    Look under either Hessco or Swirlway.
    Question HELP! passport ensemble jacuzzi tub
    My husband and I just bought a house that has the passport ensemble jacuzzi tub. the logo is a big P with a water drop in the opening of the P but who makes it and how do you activate the jets? Any words of wisdom would help us a bunch.
    thanks
    Questions from readers Guest's Avatar
    posts, emails and comments from readers reposted by Terry
    Good Morning!
    I wanted to ask casny19 if they ever figured out how to turn the Passport Jacuzzi on we are having the same problems If someone could reply it would be greatly appreciated!!
    Tracy
    DIY Junior Member captsurf's Avatar
    Jan 2006
    third coast TX
    casnet19 and guest :
    have ya'll check your braker box ? my wife and i just moved into our new house( new to us ) 10 days ago and had the same issue i was hanging out in the back yard doin some bb-q and just happened to think about that sure enough there was a braker that was off ! flipped it and walah
    now i am running into another issue with one of the damn jets leaking onto the floor under the tub and into my master bedroom i am researching this as i type !
    Best Reguards,
    captsurf
    Jan 2006
    third coast TX
    slang whats up with the hardware ? do you have a leak or is it a cosmetic issue ??
    Best Reguards,
    captsurf
    Jan 2006
    third coast TX
    Quote Originally Posted by d1bushman
    Try looking at
    hey d1vushman thanks for the link bro had my tub ( novi american ) on there as well !
    Best Reguards,
    captsurf
    Default passport tub
    Quote Originally Posted by Guest
    Good Morning!
    Tracy
    I just saw your question about turning on the passport tub. I don't know if you received any responses,but I will try to help you. If all your electrical components(wall switches, breakers,etc.) are all working properly, just fill the tub with water above the round sensor level. Then simply touch the passport logo square pad( which is probably located on the side of your tub). Hope this helps. Good luck.
    Default same problem with passport ensemble switch
    Hi,
    I've been having the same problem and its for an elderly friend who just moved into a condo with a passport ensemble tub. We got it to work once before by setting the timer and pressing the P logo.. But now nothing.
    I'm assuming that these switches have a lifespan and now they're done. Trying to get someone to help here in Ottawa, Canada has been next to impossible as now one seems to know anything about them or where to get parts
    If anyone finds out please post here!
    thanks in advance
    Luc
    DIY Junior Member bob suss's Avatar
    Feb 2011
    Vegas, NV
    Default passport ensemble jacuzzi tub . How to turn it on . Who repairs them???
    Quote Originally Posted by casny19 View Post
    thanks
    I have one of those tubs and when I moved in it was here.
    I was told by a local plimber the way you turn it on or off is to push the round knob on both side of the tub that are gold and located at shoulder height when you sit in the tub. The water must be over the grated round water vent on the side of the tub near the bottom.
    QUESTION????
    I am looking for a company that can service the tub.
    I live in Vegas. Does anyone know who can do that
  1. Passport Ensemble Jacuzzi won't turn off
    By dabears in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-04-2011, 02:56 PM
  2. passport ensemble jacuzzi tub
    By kingtutt42 in forum Shower & bathtub Forum & Blog
    Last Post: 12-04-2011, 02:51 PM
  3. Starting the Passport Jacuzzi Ensamble
    By John George in forum Shower & bathtub Forum & Blog
    Last Post: 12-04-2011, 02:49 PM
  4. Need Help finding trim kit for Hessco Passport Ensemble whirlpool!
    By katmags in forum Shower & bathtub Forum & Blog
    Last Post: 05-15-2009, 08:58 AM
  5. Passport Ensemble Pillow
    By ozzie6789 in forum Shower & bathtub Forum & Blog
    Last Post: 05-28-2007, 05:22 PM
