Results 1 to 11 of 11
Thread: Solo-Touch whirlpool control
    Default Solo-Touch whirlpool control
    I have a Passport Ensemble Whirlpool where the touch sensitive electronic on/off control has stopped working. It was turned on once and never would go off. Finally I had to turn the breaker off to be able to let the water out.
    I have read on here that Hessco is out of business and Laurel Mountain has their parts. I have found one of these controllers from Laurel Mountain. It does look to be the same size and shape as the Passport one.
    First, does anyone know if I can use this Laurel Mountain part to replace the Passport Ensemble controller I have? And secondly, has anyone changed one of these out? Our tub doesn't have any kind of panel for easy access to the underneath of the controller. I don't know if it just pops off of the top or if I need to get below it. I can move it and get a screwdriver under it, but I hadn't wanted to bust it off, if it's not supposed to come off that way.
    Any more knowledge on this is appreciated.
    Thanks.
    Default touch electronic on/off control
    Actually there is a panel that I can get in, on the back, but it still doesn't give me access to the control.
    You might get better help at this link. You have to register first. http://www.bobvila.com/BBS/Appliances/tree-page1.html
    Oops, forget that previous post. I thought you were talking about a Whirlpool washer.
    Default control
    The place to ask those questions and how to replace it would be aat Laurel Mountain.
    Thanks for the help guys. Since I've seen other questions about Passport Ensemble, I'll post what I found. I talked to Laurel Mountain. They said that they bought the Hessco molds, but directed me to http://www.uspartscenter.com for parts. They said that they were now under the Swirlway brand name.
    I haven't solved my problem, but I'm getting farther. I noticed last night that the pump doesn't turn off even when the water is let out below the sensor. So it might not just be the soft-touch control, but maybe a wire has grounded out? I'll look in that direction. Anyone seen this problem?
    I have a similar problem with my Passport Ensemble that I have been researching. From what I can tell mine was manufactured in 1992. You can usually turn it on (eventually) and once in a while turn it off with the touch control. Here is what I’ve found so far:
    There is a nut on the back of the touch control switch that holds it to the tub. There is also a wire with a ring connector on the end that runs from the switch to the control unit.
    The control unit has three wires coming from it: one to the touch control, one to the water level sensor, and one to a “no water sensor” that is located inside in the water inlet pipe.
    I am thinking of replace the touch control first (since it is hopefully fairly cheap) to see if that fixes it. Next step is probably to replace the control unit. I have not tried to contact anyone for parts yet.
    On the Laurel Mountain website, click on Help, and then owners manual, and it brings up an owners manual that may be helpful. Page 5 has a section on the “Optional Touch-control Operation” that sounds like what I have. The pictures aren’t the best but it may help.
    Thanks for the message clarksco. Sorry I didn't notice earlier. I ended up getting mine working again, so I'll post what it was in case anyone else has this. The problem I was that the water level sensor wire from the control unit had grounded out. I unhooked it from the control unit (while it had power), noticed the indicator lights, and reconnected it back together and it worked again. Still is to this day. Hope yours is this easy.
    Default Hessco Passport Parts
    We do have jet trim, controls and pumps for all the old Hessco Passport Emsemble tubs.
    go to our website and click on the 'Hessco' link under the Bath Parts section right on the front page.
    if you have further questions you may call us in the office 888-521-6183
    Hessco used HydroDynamic jets and pumps on their tubs. That is what customers are calling for the most and the pictures they send in have been for that jet mfg the most.
    Rod Kidman
    US Parts Center
    A Professional Service Firm
    "We Locate the Seemingly Impossible"
    US Parts Center
    email
    Thumbs up Touch pad / Hessco
    the touch pad you refer to was made by Sensatron - currently Mfg by HydraBaths in Santa Ana, CA - we have ALL the replacement control boxes as well as the touch pads if you so need them. What you will need to update the system is the numbers off the old box so we can match up what you had to the current replacement.
    You probably have this fixed by now but we sell all the current boxes avaialble from HydraBaths.
    http://www.bathpartsplus.com/Merchan...ory_Code=HBMFG
    Rod Kidman
    US Parts Center
    US Parts Center
    email
    Default touch pad / Hessco
    here is a link to another Sensatron box made now by HydraBaths in California which we have available at the following link:
    Rod Kidman
    US Parts Center
    US Parts Center
    email
  1. Replies: 2
    Last Post: 01-07-2012, 06:38 AM
  2. Replies: 10
    Last Post: 06-17-2011, 02:24 PM
  3. Delta Touch 2 O
    By rockycmt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2008, 05:45 AM
  4. Looking for American Standard Whirlpool Control Box?!
    By b00st3d in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2008, 07:15 PM
  5. Whirlpool water heater gas control valve replacement
    By casablanca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-25-2007, 07:12 PM
