I could use a little advise here.
I had a one piece fiberglass tub and shower unit, and wanted to replace it with a standard tub and tile the walls up to the ceiling. After I removed the unit I found out the center of the overflow and drain is 20" from the wall, the new tub is 14 1/2". Is it possible to use two 45's or 90's on the vertical pipe coming out from the p trap to get the proper distance I need? I will say I live in Florida, so I already broke the slab to move it over, the home was built in 87 and it is PVC piping. The reason I suggested 90's is I don't know if I have enough room to use 45's and have enough room for the sanitary tee at slab level.
Sorry if this was long winded, I wanted to make sure I explained everything.
