belewmoon
Gary Slusser said:Can we expect pictures sometime?
Glad to see you're still here. Yes, pics will be soon...no Super Bowl so should be this weekend.
Gary Slusser said:Yeah and I'm still here and it's just after noon on Tuesday!!
I'm thinking you've had problems or we'd have seen pictures by now...
Gary Slusser said:It's roughly 1:00 PM Sat. and that's plenty of time for at least one picture! I think the camera broke, or you're still outta water and moved in with Mom and are fixin' it today.
Raucina said:Outside of being a little bit ugly, I dont see anything that neeeds immediate surgery.... looks like this system already has had many cuts and couple jobs.
Dont know where that copper line into the foundation runs to, but looks like you will need a backhoe to modify it. Wait till it leaks.
Gary Slusser said:Now Pumpman went and told you; and spoiled my surprise...
I see something that shouldn't be, it's with the UV light installation... lose the by-pass. Buy a spare quartz.
BTW, I've sold and installed hundreds of those UVs; althoiugh they weren't Watersoft, a private label. They are made in Mechanicsburg PA. It probably is a class B light. Usually takes a 2 pin each end lamp about 19" long between the end caps. Replace it annually and sanitize the light and household plumbing. Clean the quartz every other year, replacing the two o-rings as long as the softener always gives you soft water. Otherwise clean it annaully.
Pumpman said:The suction line can be copper, PVC, galvanized pipe, whatever. I usually run a suction line at least as big as the suction port of the pump. Many times, I'll even go one size bigger if there's some distance between the water source and the pump, to cut down on friction losses.
Ron
Gary Slusser said:OK, shame on you abvout having a softener when you have an air injection iro/H2S gas filter or air pump system but... there is a filter that allows air into it with no venturi or air compressor.
Gary Slusser said:Shame also for a lack of attention to detail or comprehension. Ron said: "I think the reason there's a priming point on the copper suction line is because it's higher than the priming port on the pump. This means that you can't fill the suction line completely full of water..".
Gary Slusser said:I would not use copper! I would use 125-160 psi rated PE so in the spring I could use the same material outside/underground to the well; replacing this piece so I had one fitting on each end from the well to the pump. You can buy a 100' coil and the fittings now.
Gary Slusser said:So in another of my attempts to help you... can you figure out the importance of what that means to your system and your original question?
Gary Slusser said:hummmm another week has gone by and nothing more... and no pictures.
Gary Slusser said:Is that of the finished job? The plumbing looks like th efirst pictures.
