Results 1 to 7 of 7
Thread: Garburator problems with installation
    Unhappy Garburator problems with installation
    This is my first post here so I hope I make this clear enough. I attempted to install a new garburator and found that the fittings under my kitchen sink are seized and it seems as though they are glued together. Is there some way to unstick the fittings without sawing through them and purchasing all new fittings? Please advise. Thank you. P.S. I haven't the slightest clue about plumbing and I only purchased this garuburator because the box said it would be simple to install. OOPS!
    In the Trades GoTanklessToday's Avatar
    Jan 2007
    Renton, WA
    No. Cut, replace, enjoy. Or hire a plumber...
    Yakima WA
    The drain plumbing should not have been glued. If it really is, then cut it out and put in new without the glue.
    Default thanks
    Thank you all for replying so quickly. I was afraid it would be necessary to cut out fittings. I think I will end up waiting on this project.
    Default drain
    Some plumbers use glued together drain fittings to make it difficult, if not impossible, for the homeowner to do his/her own repairs or revisions. We would have to see a picture to determine if that is really what you have.
    Default pics of problem
    I will take a picture this evening when I get home from work and post it. I don't want to abandon this project already but I have little confidence in my ability to do this on my own and the books I've looked at aren't helping me so far.
    Smile
    This job has become way too complicated and I have hired a plumber, but I did want to thank the people again who gave me advise. Thanks!!
