which works better
jneal
I need to join 4" PVC Tee vertically to Cast Iron pipe. Is Plastic Lead better than Plumbers Epoxy? or is there some thing better?
A no-hub connector...slip the stuff in and tighten up the clamps. Or, if you have a hub in the CI, a Fernco doughnut - slide in a stub of pvc into the doughnut with the Y, then push the whole thing into the hub.
dzd9fy
Michigan
What would the way to join the PVC to the CI if the conection is going to be horizontal and under a conrete floor in the basement?
