Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: Wife wants a Water Softener. Bad idea?
    Default Wife wants a Water Softener. Bad idea?
    We have hard water that leaves calcium on the shower door, dishwasher, etc. My wife would like a water softener to help with this problem. However, the bit of research I've done reveals that water softeners have a few disadvantages like salt in the water, etc. Also, I do not have a drain in my garage for the regeneration cycle required by salt type water softeners.
    Therefore, is there some sort of newer, alternative technology to soften the water, ie, get rid of those annoying minerals, etc, that someone would recommend?
    Rancher
    Guest
    Water softners do an ion exchange, so you get sodium in your water instead of calcium, you don't get salt. There are alternatives but my understanding is they are expensive, I have my drinking water plumbed separately and filtered before I go through the softner. For the backwash cycle of the softner you don't need much beyond a garden hose unrolled out your garage door to a convient drainage point, I don't think there is even enought salt in the backwash that it would even kill the grass.
    Oh and by the way if your wife wants one, then is it a very good idea, and I would hurry up and get one installed!
    Rancher
    I just plain like the quality of water when it has been softened.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Quote Originally Posted by LawyerRon
    Don't fall for the junk magic filters that some disreputable places try to peddle. The only thing they remove is the money from your account.
    There is some evidence that soft water is not as good for you as hard water.
    Google "soft water heart disease" and you will see what I mean.
    Plumbing Instructor Plumb or Die's Avatar
    Jan 2007
    Southern BC Canada
    True. We all need the minerals that come in water. There's signs at the college I work at in the science labs where there's taps for de-ionized water. The signs say "Don't Drink". It won't kill you, but that kind of water will actually leech the minerals right out of your body.
    I like plumbing. Plumbing's my favorite.
    The waste water from a softener most definitely WILL kill your plants. Just using the softened water from the tap will cause leaves to turn yellow, unless you use potassium chloride instead of sodium chloride in the softener. Not to mention if the EPA or your county enviromental services dept. catches you running that water into the storm drain or even into your yard, the fine will be enourmous.
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    Why install in a garage? Where does your water enter the house?
    Because of the sodium concerns, I've got unsoftened cold water to my kitchen sink (as well as the hose bibbs & toilets).
    DIY Senior Member Pewterpower's Avatar
    Jun 2006
    Tampa
    The drain for my softener went thru the garage wall and into the ground next to the house. The grass and weeds loved it, my lawn mower did not. It was always 10 times thicker and lusher right there.
    I loved the soft water when I had it. But I let it go for a couple years, and now it doesn't work worth a damn, so I'm thinking about getting a new one.
    You can run the drain line up to and across a ceiling and then 30'+ to the side. Or to a dry well (depending on where you live).
    Mechanical/Physical anti-scale/descalers do nremove hardness. They are supposed to effect the water ions to prevent them rom forming scale. In closed loop systems that operate 24/7 or close to it, they can work but in residential water lines no. An ion exchange water softener is your only choice unless you go with nanofiltration, which I wouldn't suggest.
    The sodium added to the water is calculated by 7.85 mg/l times the grains per gallon (gpg) of compensated hardess. I.E. you have 20 gpg hard water times 7.85 and you get 157 mg/l of added sodium; roughly a quart. Now if you check a loaf of bread you'll find from 10-160 mg of sodium. An 8 oz glass of skim milk, 530 mg, V-8 juice, 560 mg. And so on, so the added sodium, not salt, is next to nothing and unless you're on a sodium restricted diet, it's not a concern unless the hardness is way higher than the average 10-30 gpg.
    DI (dionized) water has all ions, both positive and negative charged, removed and thereby is very aggressive water. A softener only removes positive charged ions.
    Potassium chloride, salt substitute is not as efficient as soium chloride because no softeneing (cation) resin is made in the potasium form, they are all sodium form. In many cases, depending on the salt dose efficiency of the softener, you must use up to 30% more potassium than sodium chloride.
    Running hard water to the kitchen faucet and toilets, or a separate hard water faucet at the kitchen sink, is not a good idea because hardness causes a lot of hidden problems to all fixtures and appliances it is used in. And, you must drink A LOT of hard water to get any benefit from any minerals in it. And drinking too much water will kill you. Plus there usually isn't enough added sodium (BTW all waters contain some sodium) to justify it.
    Softener discharge will kill vegetation by drowning or from sodium IF the water can not soak to below the roots of the plants/trees. So it's not a good idea to put it on the ground. Dry wells can contaminate wells in the area but some states require them because they ban the discharge to septic/sewer systems; where it belongs says the EPA after two studies. Some states, namely CA bit it's spreading, want to ban softeners due to very poor science (being repeated all over the country) saying the discharge is taxing sewer treatment plants and responsible for them not meeting chlorides content maximums. Their chlorides come from the Colorado river and the repeated agriculture reuse of the water adding it back to the aquaducts. That's not to say that old softeners don't add more than a softener should, but to require no softeners when there is no other choice but to live with 20-30 gpg hardwater...
    As to what softener, I suggest a correctly sized softener using a Clack WS-1 control valve.
    As in a previous post you can use potassium instead of salt to clean your resin beds. You can also run a hard water hose bib, prior to your softner. Here we are allowed to run the drains from our softners into our sewer systems.
    Sep 2006
    NY Capital District
    Quote Originally Posted by Gary Slusser
    Just as all factors must be weighed in the first consideration above, all factors should be weighed in the second. I'm dealing with 8-10 gpg, and I prefer the taste of the unsoftened water. In 25 years, I've had no problems with fixtures...our major objective is clean rinsing for the hair of the XXs in the house (most bad hair days eliminated!), clean laundry and spot free dishes.
    Quote Originally Posted by TedL
    Ted,
    My water enters the house in the garage. Also, that's where the water heater is. I don't know of another location I could install it in.
    We always ran a third water to the kitchen sink ( it tastes better) and certainly wouldn't waste softened water to the outside sillcocks........................
    Toilets, soft water helps to keep them clean.
    I've never considered soft water to be a disadvantage.
    Good water has no taste. It's things in water that give it a good or bad taste.
    In the last 20 years I've sold and serviced thousands of softeners and talked to many thousands of people across the US about their water quality issues and it is very rare for anyone to mention being able to taste any difference in softened or hard water. Unless the softened water being iron, manganese, copper, lead, radium etc. free (all+ are removed by a softener) causes an improvement in the taste.
    Some folks think they can tell the difference because the hardness has been removed but give them a blind test and they can't; mostly it's mental. Some of that comes from the word on the street that softened water isn't good for you. That's usually due to folks seeing all the salt in the brine tank dissappering and mistakenly thinking it is added to the water. 7.85 mg per roughly a quart of softened water times the gpg of hardness in the water; in your case at 10 gpg you get 78.50 mg of added sodium and it is very unlikely that anyone in your family could taste that but... it's next to impossible for most folks to get any taste from only 10 gpg of hardness.
