Results 1 to 5 of 5
Thread: Delta Monitor 1700 Valve question
    DIY Member elgato's Avatar
    Jan 2007
    Phoenix, AZ
    Default Delta Monitor 1700 Valve question
    Delta now ships the universal valve for the Monitor 1700 series without the cartridge. I does come with a cap. Can this rough-in valve be installed without the cartridge and trim and water pressure restored? The cap does not block the hot and cold inlets internally so water could flow together.
    Thank You
    Default cap
    That is the reason for the cap, so you can wait until after tiling to install the cartridge.
    Besides the cap, there are 2 screw valves on the hot and cold supplies that you can use to turn off supply.
    (important note: I'm not a pro)
    Default valves
    Not all valves, in fact very few, have the integral stops.
    I just installed a new Delta 1700 universal valve and the version that was shipped to me had those stops.
  1. help identifying shower valve. Delta Monitor 17
    By justme1977 in forum Shower & bathtub Forum & Blog
    Last Post: 03-02-2014, 03:13 PM
  2. Question about rough in - Delta 1700
    By Speedy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2010, 10:42 AM
  3. Delta 1700 Thermostatic valve - don't see this on Delta site
    By SliderJeff in forum Shower & bathtub Forum & Blog
    Last Post: 07-27-2009, 07:10 PM
  4. Delta Monitor 1700 (1768) "Graves" tub/shwr valve
    By holybuzz in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2007, 08:03 AM
  5. Delta Monitor Question
    By jammin in forum Shower & bathtub Forum & Blog
    Last Post: 03-19-2006, 09:41 AM
