Results 1 to 5 of 5
Thread: Lead sleeve - what does it do?
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    Default Lead sleeve - what does it do?
    I found my basement toilet drain has a lead sleeve over the flange going into the cast iron. What purpose does it serve? To smooth the inside surface when a set screw mounted flange has been used??
    If I remove this sleeve to inspect the flange and replace the toilet mounting bolts, are replacements (or substitutes) still available?
    Default lead
    We would have to see a picture, because usually that lead "sleeve" is the actual drain pipe for the toilet.
    Sep 2006
    NY Capital District
    Here are pics:
    Top view: http://123pichosting.com/images/8253P1010114.JPG
    Side view: http://123pichosting.com/images/5815P1010116.JPG
    It's a basement toilet, on a slab. House built 1985; basement was finished in 1989; I removed a 1994 AS toilet to replace with something that works.
    (I've owned home for 5 months.)
    There's a flange below the sleeve, and it goes down into 3" CI, apparently with a hub at the top.
    Default pictures
    You were too close and/or used too high of a resolution for the pictures. They are huge and blurred.
    Sep 2006
    NY Capital District
    Quote Originally Posted by hj
    Clicking on the link and resizing the Explorer window to about a quarter of the screen lets them show well.
