Results 1 to 10 of 10
Thread: need diagram for plumb on a double kitchen sink left side 10" right side 8"
    cottagepeople
    Guest
    Exclamation need diagram for plumb on a double kitchen sink left side 10" right side 8"
    Please help. We installed a new granite double basin kitchen sink
    The left side is deeper than the right side.
    I dont know how the plumbing should be. The way I did it , the water
    is leveling back into the sink. Can anyone send me a diagram of how it should be. We have a dish washer with air vent on top also. Here is a link for a pic of novice handywork... http://up4salebyowner.com/sink.jpg
    HELP Thanks ronandtheresa@gmail.com
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    I said it on the plumber.com and will say it here. The drain line needs to be snaked.
    DIY Member casman's Avatar
    New York
    Quote Originally Posted by kordts
    Why would a new counter-top and double sink clog the drain?
    Oct 2005
    exurban Chicago
    Read the post. The plumbing backs up. The countertop is just fine, the countertop has nothing to do with it. The poster needs to have a plumber with the proper equipment snake the drain.
    scratch-pad engineer and mechanical fabricator leejosepho's Avatar
    Nov 2006
    Yes. The picture shows everything fine under the sink, but the shallow side of the sink drains into the deeper one because the drainage has nowhere else to go.
    Oct 2005
    exurban Chicago
    lee,
    are you a plumber? The sink backs up because the drain line is clogged.
    Nov 2006
    lee,
    I am an across-the-board mechanic, and it does not take a professional plumber to know the drainage has nowhere to go ... as in "the drain is clogged". I was simply using different words to confirm what you had said.
    Rancher
    Guest
    Yeah, needs a snake run down that convenient clean out to the left of the P-trap.
    Rancher
    And run a lot of water while pulling the snake out.
    Nov 2006
    Quote Originally Posted by plumber1
    Once flow has begun, I have heard that alternating between a few minutes of cold and then hot water can cause blockages to contract and expand and break loose from the inside walls of the pipe ... kind of like a "heat wrench" for plumbing internals. But, I do not whether that really works even though I have done it a few times.
