Thread: Solvent Weld vs No Caulk
    DIY Junior Member Blaze's Avatar
    Dec 2006
    Ontario, Canada
    Question Solvent Weld vs No Caulk
    I was wondering which solution would be best for my situations.
    I am installing an acrylic corner shower (base and walls) from Maxx. The bathroom is on the second floor above my family room.
    Should I use a solvent weld shower drain or a no-caulk shower drain, and why?
    Mark
    Plumber jimbo's Avatar
    If you have access from a ceiling below, I prefer a solvent weld. If this is on a slab or otherwise does not have access, then you will need the no-caulk.
    I prefer a glue drain in either instance...just MAKE SURE you get one that you can unscrew the drain after installation in case you have a leak...then tyou can screw it out...re putty and re install...
    actually this is one of the few times I might use silicone over putty.....
