elgato
I have taken your recommendation for the Delta 1700 series. Does it hold true for the models with:
Separate volume and temperature controls for maximum comfort. Handle adjusts volume; dial on handle controls temperature.
Monitor® Scald-Guard® valve keeps water temperature within +/-3ºF.
Is it less reliable than the standard 1700 models?
Are the repairs more expensive or difficult?
Are there flow volume issues?
Is there a better choice if you want volume and temp control?
Any comments or recommendations would be appreciated.
Also, can anyone explain the difference between the T1700 valves and the standard 1700 valves?
Tom
Tom
