Connecting plastic pipe to galv. steel
Mike B
Virginia
I am replacing the plumbing under my bathroom sink and would like to use plastic materials. However, the stub coming out of my wall is what appears to be galvanized steel and it is not threaded. Is the anyway for me to connect a plastic p trap assy to this pipe? Thanks
Norcal1
Plumber/Owner
Use a "Mission coupler" to connect the steel to plastic. It's a rubber sleeve that is wrapped by metal. You can probably find something like it at your local hardware store.
Good luck
Shacko
Master Plumber-Gas Fitter
Rosedale, Md
Galve. to plastic
I have to agree with Norcal, use a Mission coupling or a Fernco.. Lots of luck.
"If all else fails, read the directions:
HawaiiDisney
I installed the sink/vanity today. Everything went very well. Thanks for the suggestions!
