Thread: Can you Recommend a Wall Mounted Toilet?
    Default Can you Recommend a Wall Mounted Toilet?
    I need to replace my wall mounted toilet and I have no idea which toilet to buy. Does anyone have a recommendation on which wall mounted toilet to purchase or know where I can find out which one works the best? Does anyone have any good/bad experience with a wall mounted toilet?
    Thanks, Debbie
    Default use wall hung as key words
    they're all good.
    the actual flush you get depends a lot on your venting, behind the toilet, in the drain system. just in case that is what you meant when you asked which ones are good. None are bad. Enjoy.
    david
    I sell a lot of the American Standard Glenwalls.
