Thread: Water Softener
    Mec. Elect. Engineer DarylF08's Avatar
    Dec 2005
    St. Louis Missouri
    Default Water Softener
    My Neighbors replaced there W.S.
    Gave me there old one. Nothing wrong with it.
    Maybe 4 years old ( Kenmore )
    Has not been hooked up for about 6 months.
    What or is there anything special I should
    do to the WS before I install ?
    Daryl
    As you install it pour 3-4 gallons of water into the brine tank unless there is water in it. If so then watch you don't overflow the water on the floor. If there is no salt in the tank, add 40 lbs. After it is installed, add 1/4 cup of non-scented bleach into a quart of water and pour that into the water in the brine well in the brine tank. Then do a manual regeneration. That is to regenerate the resin and sanitize the softener.
    You can go to the following link and their animations to see how a softener works.
    www.kenmorewater.com
    Dec 2005
    St. Louis Missouri
    Thank You,
    I'll try it out,and if I have any ?
    You guys will be the first to know.
    Thanks Again
    Daryl
