please give me some advice on piping my sewage pump.
I have an existing in ground basement sewage pit, with all the underground plumbing in place. it was roughed in back when the basement was poored for a future bathroom. as you may have guessed the future has arrived and I am installing the bathroom.
the pit is empty with the 4inch drain pipe entering from the side. I have purchased a cast iron sewage pump with 2" discharge, a 2" PVC check valve, and a 2" gate valve. my questions are?
1) check valve - Horizontal vs Vertical? the instruction with the pump and valve mention horizontal for pumping solids. my overhead sewer is almost directly above the sump pit about 8 feet. it would be a simple run (no extra turns)to install it verticly and would probably be cleaner if I ever needed to service it? if I go horizontal I will have to make extra turns just for that reason. so what you experience? do I need to install it horizontally, or will verticle work just as well?
2) next since I need to go about 8 feet vertical from the pit to the overhead line (+3 feet down in the pit), does it matter were the check valve & gate valve go. another words do I put them close to the floor/pit, half way up the rise, or near the top of the rise? I am concerned that if there is 6+ feet of yuck sitting on top of the check valve in bewteen uses, that something may get plugged up?
3) any other advise, does or don'ts?? I only want to do the job once and do it right.
thank you
thank you
