If your going to use a pressure switch, you must have a pressure tank, be it a galvanized or bladder tank.
You can also use 2 relays to turn on the pump with the control circuit being 24 volts. Wire an irrigation timer into one relay(which is 24 volts) and your float into the other relay from a 24 volt transformer. Jumper the two relays line and loads together and either system will turn on the pump.
bob...
