Carmel Corn
- Messages
- 52
- Reaction score
- 0
- Points
- 0
jackofalltradesman said:"If a pocket of air is in the area where the impeller is turning, IT WILL NOT HAVE ENOUGH FORCE TO OPEN THE CHECK VALVE."
Sounds like a very weak pump, that is, a pump that is stopped by a pocket of air. In any event, there are ways to work around the issue of air-lock without resorting to drilling the hole. I mentioned one with the electronic sump switch/ high water alarm /DC back-up set-up that I have, and that is exactly the system I recommended for someone with frequent cycles. Another possible solution is a stronger pump that is not locked by an air bubble or possibly something like the built-in check valve on a strong sump like the Flotec Floodmate 7000, or the Hydromatic 1/2 h.p, the Wayne 3/4 h.p. or 1 h.p., etc. I wonder if more powerful pumps are immune to this I never use 1/3 h.p. pumps like tract builders, so maybe that is why I never see this issue in any homes.
You call the water backflow out of the pipe on each cycle a "small amount". The water that comes out of that hole is all of the water in the 1.5" pipe from the hole up to the check valve. It could be about a half of a gallon or so. For someone who has constant water coming into their drain tiles, starting off with an extra half gallon in the pit is the LAST thing they need.
The solution I came up with to deal with high water table/ frequent sump cycles is what I actually installed in my home. I have to say it works great.
I never heard of the requirement for the hole in the discharge pipe 30 years ago, but if Zoeller recommended it then, maybe they should consider a better solution to air-lock now. Just like the electronic switch in place of the old unreliable and problematic tethered float, there has to be a better way.
As a builder, I would like to see a pump company come up with a sump pump system that does not air-lock, that has no tethered or mechanical float, and maybe even an electronic monitoring capability where a homeowner can have a digital monitor upstairs that gives them status on the pumps operation, water level in the pit, how much water is being pumped per hour, back-up battery charging/ status, etc.
As in a lot of things, it's not just the specs but the quality of the equipment. I would tend to think that a 1/2 or 3/4 hp pump would be too much for most residential basements. IMHO - a Zoeller M-53 or Hydromatic VS-33 are 1/3 HP units and plenty strong for the vast majority of residential pits without having too much HP (I personally like the float mechanism design on the M-53 better because it tends to not get "gummed-up" as much as the SJE mechnical floats on the Hydromatics...tradeoff is that the M-53 does not feature a piggyback style plug and has fewer lifetime on/off cycles vs. other mechanical types). Second, these type of units have a built-in vent hole which helps to eliminate air-lock (Zoellerpump still advises drilling the hole in the event the small built-in vent hole clogs). I personally would stay away from Flotec.
