For two months, I have been trying to find the source of a drain fly infestation in my basement. I finally discovered that there is water in one of the clean-outs of a drain line under the basement cement floor. The flies are clearly breeding from this source (about 10 flew out when I dug out some of the soil below the clean-out plug). The clean-out pit is cement on the sides, but has a mostly dirt bottom.
There is a sink about 2 ft. from the clean-out. When I put food coloring down the drain of the sink and run the water, about a minute later, the water in the clean out pit turns the color of the food coloring so I know that I have a leak somewhere. I have to suck the standing water out of the clean-out pit with a shop-vac to get the water to flow into the clean-out. The water level in the clean-out does not appear to go up even when the sink is on full.
Now here is the mystery part. I had the line inspected today with a camera. We looked at the main line, the line connecting the sink to the main line and another line further up from the sink. There were no OBVIOUS leaks or cracks or standing water. My food color test proves that there is a leak, but my only guess now is that it is small and/or possibly under some of the scum inside the pipe (these are 80+ year old cast iron drain pipes).
I would like to get an opinion on next steps which I see are as follows.
Have the line inspected by another drain company (the first was Roto Rooter). I was thinking that power washing the inside of the pipe may help remove some of the scum to show a leak?
Try and seal up the clean-out with hydraulic cement. This will not fix the leak, but it may stop the drain fly problem since they will be “trapped†under the slab. My guess is that they may find another way out elsewhere.
I am also considering having the pipes lined with an epoxy liner. This was just demonstrated on “This Old House†and I would think that this would fix any potential hair-line cracks. I do not know the cost for this procedure, but figure it would be reasonable to just do 10-15 feed of pipe since I am fairly sure the leak must be close to the clean-out due to the speed at which the food coloring shows up.
Thank your for your help on this strange matter.
-Justin
-Justin
