Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: 1/2" PEX supply lines to Moen Shower valve
  1. #16
    Aug 2008
    Those aren't "Pex" elbows. Those are sharkbites. See if your locale approves of those type of fittings in concealed locations.
  2. #17
    Software Engineer BlackNoir's Avatar
    Mar 2009
    Centerville, MN
    True, they're not actually PEX elbows.. I guess I was just using them as example. The question still stands, which is, is there any reason not to use PEX elbows?
    But, a good point about the sharkbites in concealed locations. I might just have to invest in a crimper after all.
    So if you shouldn't use sharkbites and the Zurn Brass connectors have a class action lawsuit against them making me NOT want to use them, how exactly can you use PEX in a concealed location? Would you recommend the new Zurn Platic connectors? I saw a bunch of those at ******* but hadn't heard anything about them yet.
  3. #18
    Sharkbites have all the national certifications for use in closed locations, but local rules might trump that...
  4. #19
    Dec 2007
    Kitec, Zurn, Rehau, Durapex...
    Just a few hiccups in the world of pex...
  5. #20
    DIY Junior Member mcintoshmc's Avatar
    Dec 2012
    Los Angeles
    Ok, and 3 years later where are we on all this? I'm in the planning stages of a PEX install although my older more wise neighbor suggests I go with copper because it is tried and tested. I'm going with PEX regardless, but 3 years later, how should I connect to the shower valves?
  6. #21
    If the valve is supported in the wall, you can use PEX adapters to the valve body. I normally use copper on the valve, support it, and then run PEX to that.
    Any tub spout must be full size pipe, Copper, or brass threaded fittings.
    PEX and PEX fittings will restrict too much on a diverter tub spout.
  1. supply lines for new shower
    By RobertZ in forum Shower & bathtub Forum & Blog
    Last Post: 03-26-2012, 10:26 PM
  2. Help with a shower supply lines install
    By Dom Z in forum Plumbing Forum Discussion & Blog
    Last Post: 08-18-2009, 10:18 AM
  3. Solder supply lines to valve or use threaded?
    By johngaul in forum Shower & bathtub Forum & Blog
    Last Post: 11-14-2007, 06:46 AM
  4. moen shower valve supply question
    By spooner in forum Shower & bathtub Forum & Blog
    Last Post: 02-18-2007, 04:42 PM
  5. Can I use flexible supply lines from shuttoffs to shower valve?
    By Jhawk in forum Plumbing Forum Discussion & Blog
    Last Post: 10-10-2006, 06:24 AM
