Results 1 to 7 of 7
Thread: Backflow device question
    DIY Member chetwynd's Avatar
    Jul 2005
    California
    Default Backflow device question
    Hi,
    My girlfriend works for a property management company, and the backflow devices on water lines at their properties keep getting ripped off for scrap metal (stupid meth addicts). Anyway, she needs to find something other than copper or brass or whatever it is.
    Do they make anything else? Any ideas?
    Plumbing Contractor srdenny's Avatar
    SF Peninsula
    How about putting cages around them? With booby traps and bungi stakes!
    Rancher
    Guest
    Quote Originally Posted by chetwynd
    the backflow devices on water lines at their properties keep getting ripped off for scrap metal Thanks!
    Unless they've changed them those backflow devices have a stainless steel set screw that you are "supposed" to screw into the hose bib to permantly secure them, then the head of the set screw is broken off to keep it from being removed.
    Rancher
    Default backflow devices
    They are referring to the large ones on the water mains at the meters. You can get stainless steel ones, but they will cost as much as two or three of the brass ones. Metal cages with locks on them are the usual security devices.
    Yeah... then the theives can take the cage and lock in for scrap too! Bolt cutters work wonders.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    Ames makes a good one. stainless steel body and easy to service.
    Default cage
    In the first place the cages are bolted to a concrete pad in the ground, which would make them more difficult, but not impossible to remove. But since the thieves have to be in and out in a matter of minutes removing the bolts would normally induce them to find an easier one to steal. Second, cutting the lock only opens the access door. Getting to the connections usually requires that the cage be removed, or spending a lot more time trying to access them. Again, time they really may not have.
