Results 1 to 14 of 14
Thread: Delta to Price Pfister Roman Tub replacement
    DIY Junior Member cstdenis's Avatar
    Dec 2006
    Florida
    Question Delta to Price Pfister Roman Tub replacement
    I know this is probably a dumb question, but I am really confused. I have an old classic delta polished brass roman tub 2-handle faucet. I purchased a Price Pfister Marielle replacement which came with pipes, etc. I am having a hard time getting the old handles/pipes out of the tub and I'm really unsure about whether I can even do the replacement without tearing out tiles, etc. I thought it would just be a matter of changing out the insert to connect to the handle and change out the handles, but apparently I'm wrong. Do I need to get a plumber to do this?
    Thank you.
    Feb 2005
    Talking stick with DELTA
    Take that Price Fister back.....they are junk
    you already have a Delta
    all you go to do is go to a plumbing
    supply house and simply buy the TRIM KIT for about 90 bucks..
    in whatever delta faucet design you wish to install......
    if the faucet is PB it is probably a mid 90s Delta
    it is still interchangeable with MOST of the new stuff,,
    and you should just have to change out the tub spout with
    an allen wrench
    and the new handles and escuption plates
    should jsut screw off and you should be albe
    to re-use the basic body
    price fister is junk anyway....
    Default Delta tub faucet
    I'm trying to replace a Delta roman tub 10"faucet from 1986 and can't figure out how to remove it, there is no set screw behind the faucet. any ideas, thanks
    Plumber Cass's Avatar
    While I am not familiar with that particular one, if there is no set screw to be found anywhere on the top side then it is held on from under the deck it is mounted on. If it is like many I have seen then you will have to gain access from some where and many I have seen are completely enclosed by ceramic tile which has to be broken to get there. Lets see if someone else has another idea.
    Default roman tub
    Spouts with set screws are a fairly recent innovation. The old ones were held in place by a lock nut under the deck and a drive pin into a hole in the dect to keep it from turning. For those you need to access the underside of the deck, but you would have to do that anyway to replace the faucet.
    Dec 2006
    Florida
    Default Will all delta faucets work?
    OK, can I replace it with any Delta faucet/handles? I don't want the ugly acrylic ball handles anymore. I don't have a plumbing supply in my area.
    Also, my escuption plate on the hot water handle is stuck. I tried WD40 and silcon spray. Any ideas?
    Thank you.
    Apr 2005
    If you call Delta's 1-800 number and describe your situation, they will set you up with what you need in style and selection to retrofit to your situation.
    That part you are having trouble removing; try turning it slightly in a tightening motion and then reverse motion. This sometimes opens the thread pattern and allows that small movement to allow the connection to free up.
    Dec 2006
    Florida
    Default thanks!
    Thank you! I'll try that!
    Yes,
    Call Delta. Their CS is great. Stay away from Price Fister. We bought a faucet from them for our kitchen and it has been a PITA since then.
    Good luck!
    Dec 2006
    Florida
    Default called delta - still confused
    Well, I called Delta and they asked me "is the base of the current faucet square?" I answered the base of the current faucet (spout) is kind of rectangular. This freaked them out and they said they can't gaurantee that any new faucet will work with it. So I thought maybe we are not communicating and told them the hole in the tub was circluar and the valve stem was circular as well. I don't think I got my message across, because I got the answer "well you can try a newer faucet and see if it works." I don't feel like wasting $300+ just on an experiment. So I'm not sure what to do. I took some pictures of both the faucet and handle valves and stems. Can someone give me some advice please?
    spout and valve:
    handle v
    alve:
    Carol
    The new Roman tub faucet by Delta does not match up with the old valve.
    You're looking at a complete replacement of the faucet if you want to change the tub spout.
    This is the new replacement here.
    The old Delta Roman tub faucet removed. We had to enlarge the holes to 1-1/2" for the new stems and spout.
    We removed six tiles on the side of the tub box to get access to the valve.
    The Old Delta valve had been run in tubing smaller than 1/2". We wound up removing that and using PEX to the new valve, which by the way is now 1/2" copper.
    I wish I had taken a picture of the rectangle we had cut out with a sawzall. The general borrowed our saw and did a nice clean job of it. He plans on reinserting it now.
    The old tub spout was fastened from below the tub. There is no replacement without undoing it from the underside. The new trim does not work with the old rough. A new rough was needed.
    Delta BT2710 was used here.
    I have used more Pfister faucets, and have them in my own house, than Delta.
    DIY Junior Member robert13084's Avatar
    Nov 2013
    waco, TX
    You probably wont find just the trim since delta changed there faucets. Tear it out and put in a new one. Delta is junk! Pfister makes a better quality faucet!
    At least they did. Not sure how they are going to be not that they are a China company, and have to comply with the anti-lead laws, which all companies will have to do somehow.
  1. Price Pfister faucet stem replacement
    By khayes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-05-2013, 07:16 AM
  2. Price Pfister Roman Tub rough valve
    By mlprachar in forum Shower & bathtub Forum & Blog
    Last Post: 12-18-2012, 04:38 AM
  3. replacement trim kit for old Pfister roman tub
    By mako77 in forum Shower & bathtub Forum & Blog
    Last Post: 10-03-2012, 12:50 PM
  4. Need help identifying a Roman faucet, Price Pfister
    By michaeldiy in forum Shower & bathtub Forum & Blog
    Last Post: 08-06-2010, 03:00 PM
  5. Replace Moen Roman Tub with Price Pfister
    By teamdean in forum Shower & bathtub Forum & Blog
    Last Post: 04-22-2007, 07:29 PM
