I need some troubleshooting help, big time.
When in my downstairs master bathroom that is adjacent to the water heater in the garage, I get an in-the-wall dripping sound ONLY when running the hot water in the sinks. I removed (destroyed) the drywall from the garage wall and cieling, and have only found a PVC vent pipe that rises between two studs until it makes an 90 degree for about 2 feet into the garage (parallel with cieling), then makes another 90 degree and heads up through the second floor tongue-in-groove OSB deck.
I believe that the PVC is some sort of vent pipe, and that when I grab it at the elbow the dripping noise ends. Is this posssible? The pipe and elbow joints move pretty easily when grabbed, and I am in North Carolina where it recently became a little chilly. It is a tract house built during the early 90's, and I am not completely confident to rule anything out.
The plumbing in my house is poly with copper elbows if that matters, at least what I can see of it. I know the issues with poly and am hoping it is not that. I don't believe it should be with the copper fittings.
Please let me know if you need more info. I am hoping to solve this issue before demolition heads toward interior walls. I tell my wife I am going to tear our house down looking for a drip. The crown royal highballs it is forcing me to drink does not make the situation better!!!!!
Thanks in advance,
Dave
Thanks in advance,
Dave
