TimL
Hi,
I've got a 4" cast iron soil pipe that passes through my laid-up stone foundation right where my chimney/fireplace base is located. There is an ash cleanout below the fireplace, and if you can believe it, the pipe passes right through this open space. As you stand in the basement, you can look into the ash cleanout, look up, and see the pipe passing through. And it passes through at about a 45 degree angle from right to left.
I'll follow this up with some photos later today.
A crack and leak has developed in this area. It took a long time to diagnose, because normal use does not cause enough leaking. But do a few loads of laundry and drain our new bathtub, and suddenly there's water on the floor.
A year or so ago, the soil line got blocked. A local rooter type company came out and blew the blockage down the line and then scoped it. The pipe extends straight out into the yard about 30 feet to and old stone drywell. (The house was built around 1830). There was a belly in the pipe about halfway out, but we didn't notice anything in the first couple feet of pipe.
Immediately inside the foundation wall was a tee that had cracked on the topside. A chunk of cast iron had fallen in, and this combined w/ the belly in the soil pipe probably contributed to the blockage. I replaced the tee w/ 4" PVC wye and a cleanout.
If I remove this tee, I know it's a straight line out of the house. I'm wondering if a length of 3" PVC will fit inside the 4" soil pipe. If so, I could pass enough of it down the pipe to clear the leaking section, and hopefully seal everything up inside the foundation at the bell of the soil pipe. Then reconnect to the PVC already inside the house. I'll have to rework the transition from the 4" to 3" to make sure I don't cause problems.
Any chance this would work?
I'm concerned about starting a proper soil pipe replacement job in the winter here in upstate NY, and the fact that it passes through the chimney base worries me too.
Thanks for any advice.
Tim
Tim
