I just read through this again. Valveman says the water is moving through the pipe at 10 to 20 gpm. This is correct depending on size of submersible pump. Sam says the check valve at the top can cause water to be sucked into the suction line. True, but this would only happen with a jet pump. Jodan's pump is at 265', so we know it's a submersible pump.
So to fix this man's problem as per Ranchers request, I recommend pulling the pump and replacing the check valve. I have seen a lot of check vavles over the years go bad. Not because of the poppit so much, but because of the SS spring that slowly closes off the poppit when the volume drops as pressure rises (this spring is used to prevent hammer). I think this spring is broken and the poppit is staying close to wide open. When the pump stops, bang it closes hard, when the pump starts, bang all the way to the nut that prevents it from getting pumped into the tank. Since Jodan didn't answer my question of when he heard this noise, I will assume it is both when the pump starts and stops. This would indicate the bad spring theory.
bob...
