Results 1 to 2 of 2
Thread: Wallboard Question
    DIY Junior Member strafe's Avatar
    Jun 2006
    Hawaii
    Default Wallboard Question
    Have alcove type tub/shower installation in a 5'x11' bathroom. Used concrete wallboard for the 3 sides of the alcove area of tub/shower extending just slightly beyond the depth of the tub and up to the ceiling.
    The ceiling is not water resistant wall board. Is this OK?
    The other question is: do I need to use water resistant wallboard for the rest of the walls or can I just go with regular drywall?
    Thanks, JM
    If it gets a good coat of primer and semi-gloss paint you should have no problem. In any high moisture area the moisture resistant drywall is recommended and it should be 1/4" off the floor to prevent it from wicking moisture/water from the floor.
