Sounds like the male threaded part is a MIP adapter soldered onto the copper pipe directly and the head just screwed on....
It may be that the original plumber made up his own custom nipple and that it might just screw out of a fitting inside the wall (try to loosen it but don't force it or you risk bending/kinking/breaking the pipe....
More likely though you will have to get a local plumber to solder the correct adapter onto the pipe....
