Mikey, you said it well............
Printable View
I get the impression the plumber that disassembled things was there when things were working OK. Everything point to clogs that form, screw things up for a while, then clear themselves. Given the number of fixtures and the wild turns, and the likely buildup of cat litter (the new clumping litter looks like a good thing to use to plug holes in leaking dikes), I'm leaning again toward my initial advice...:D .
Truth in humor Mikey. Clumping cat litter is Bentonite Clay.Quote:
Originally Posted by Mikey
And it is in fact used as a waterproofing sealant. See below:
http://en.wikipedia.org/wiki/Bentonite
"The property of swelling also makes sodium bentonite useful as a sealant, especially targeted for the sealing of subsurface disposal systems for spent nuclear fuel [1] [2] and for quarantining metal pollutants of groundwater. Similar uses include making slurry walls, waterproofing of below grade walls and forming other impermeable barriers (e.g. to plug old wells or as a liner in the base of landfills to prevent migration of leachate into the soil)."
Especially, If you have an expensive new plumbing system-you would have to be out of your mind to flush this stuff.
Mike
It really sounds like you hit the nail on the head. I have not had any gurgling since they came out to open things up. (fingers crossed)Quote:
However, it was not once in a while. The thing gurgled at least 2 or 3 times a week for as long as we have lived here, about 2 years.
Who would I contact to check to see if the venting is up to code?
I have looked at those pipes underneath for about a week now and I keep thinking what your saying. Why not take a direct course to the main line? The extra twists and turns will only cause problems.
How big of and undertaking would it be to correct that?
Oh, its San Jose CA not San Francisco. I'm not sure if that matters or not just thought I would mantion it.
When they "opened things up", did they actually find any clogs or crud in there that they cleaned out?Quote:
Originally Posted by scoobydo
I would believe that. With the fall of the upstairs lines and (I'm still assuming) no vents, you might see gurgling with minor clogs which might clear themselves regularly. If they occasionally don't clear themselves, then you'd see backups and overflows.Quote:
I would call the local building department people and ask for an inspector to come out. You might have to pay for this, but on the initial call, tell them the situation, and that the conformance to Code has been questioned, and you'd like an opinion from the horse's mouth.Quote:
You'd have to get a quote from a plumbing contractor for that. It would depend of whether there's a clear path for the rerouted pipes or not, among other things. I'm a little surprised the plumber that was there didn't comment on crazy routing of your pipes, so maybe there's something I'm leery of that's OK in your area.Quote:
Probably better, in that it's a smaller area and the Building Official might be more inclined to help a resident than in a large city. If you know anyone on the city council or whatever they call it there you might get some leverage through him or her.Quote:
Good luck...
