Adding Shower drain in Basement
I'm in the process of adding a shower drain in my basement. My house is fairly new only 2yrs old. I had rough ends for toilet and sink added in during initial contsruction but now I would like to have a shower also. Can anyone give me the best approach as to adding the drain. Can I tap into the existing cleanout stack that runs above the concrete slab or would I be better off breaking the concrete to connect shower drain up with cleanout plumbing below.
Thanks! Derrick
Thanks for the adive. If I decide to take the easy route by raising the shower base how would I tap into the clean out stack. Would I add a (T) just above the grade to attach the drain for the shower? I know I would need a 2" trap beneath the shower drain so I'm assuming I would need to rasie the shower base at least 6" minimum?
Or should I still stick with forming a trench thru the concrete?
1 Attachment(s)
Adding Shower Drain in Basement
Thanks again! OK, you talked me into breaking up the Concrete. Here is a picture I attached just the give a lay out of what I'm trying to do. On the picture you can see where I plan to trench into the existing Clean-out beneath the c-crete. As far as venting I assumed the Clean-Out line is already vented thru the house plus the venting on the sink rough-in is connecting up with the clean-out line below the C-crete. Please let me know if this is the best approach.
Adding shower drain in basement
Sorry, I'm a first timer. I didn't word my plan correctly. I plan to tie into the waste line drain beneath the concrete slab not the clean out. I'm assuming the waste line drain is vented along with the sink rough-in that is connecting beneath the slab also. On the picture there is a pipe which is coming from my first floor and going into the concrete. The (T) that comes off of it I'm hoping is for the sink.
From one first-timer to another
I appreciate what yr doing; I'm doing it myself too. Kudos to ambition. That being said, you need to get some good books on plumbing code before you go any further.
To me, venting was the most difficult thing to grasp. I would originally have thought what you think, but I've been given advice from experts (namely, HJ and Gary) and have read everywhere that every single fixture needs to be individually vented. If you don't do this, there are many reasons why the shower trap may fail to work properly. In your proposed configuration, I'd speculate that the toilet draining past the shower branch could pull water out of the trap, or that if the shower is far enough from the drain, draining water from the shower could siphon out its trap.
I assume you'll build a wall between the shower and the drain, so that'd be a convenient place to put the shower vent. That vent line can join the sink or toilet or main vent line along the ceiling of the basement. You don't have to run a separate, dedicated vent out the roof - just a separate branch to the fixture.
Also, I defer to Gary's experience with a hammer drill, but for what it's worth, I used an SDSMax rotary hammer which is a quite a bit more powerful than a hammer drill, and it still took reasonable effort to drill and chip out a sump hole. I drilled 1/2" holes on the perimeter of the hole and chipped out the center. I will say, though that it made for a neat job, and was virtually dust free. I think, though, in the end it's worth the extra $ and clean up to saw and chip with a larger hammer. The less stress you can put on your back, the better (IMHO).
BTW, where's the toilet vent? Am I missing something?
PS: I'm jealous your main drain exits the house below the slab! I have to use a pump.
Thanks again for advice. As far as the toilet vent I don't know where that is. What you see in the picture is pretty much the rough-ins for 1/2 bath (sink and toilet. I don't know if the plumber left of the toilet vent by mistake during the initial contruction. Or there's a possibilty it could connect up with sink vent beneath the slab. I'm sure the plumber could have not forgotten to add toilet vent on????
