UltraMax II vs. Eco Ultramax
Hi Terry,
First off, this site is a lifesaver when planning a modular home!
My architect has specified the Eco Ultramax because we decided we wanted the larger 3" valve. However, it doesn't have the double cyclone flushing.
Do you have any insight as to whether the Ultramax II would be a better bet? Would the MaP rating make a difference here?
Thanks so much!
3 Attachment(s)
Review TOTO Ultramax (1.6 GPF / G-Max Flush System)
I'm a TOTO fan! :D
I agonized on this decision (what toilet brand and model) for a long while and made the decision to go with TOTO with all the great feedback I hear about them. Then I had to decide which model...TOTO makes so many toilets you kind of get overwhelmed with information overload when you do your homework. I wasn't sure about the rough in size either but Terry helped me out with that in another post...THANKS TERRY!;) The 12" rough in worked perfectly.
Well I went with the Ultramax ADA height 1.6/GPF G-Max flush system.
This thing is awesome. I haven't double flushed yet. It's stayed clean with no skid marks or anything gross like that. Unlike my old Sterling toilet that didn't always rinse good enough or get rid of everything all the way.
My parents just bought a new toilet from Home Depot (can't remember the brand name). I'm sure it was a cheap toilet...my dad won't spend money for higher quality.
That toilet sucks...it doesn't get rid of all solid waste all the time and you have to double flush. He saved a buck on the toilet but will spend more money on water and sewer taxes.
Anyway...it is a great toilet and I made the right decision to go with TOTO.
It is a bit louder (than Sterling toilet)...more of a gurgle toward the end of the flush. Boy, it has great suction...it's that suction that makes the gurgle.
But it's quick and thorough. Refill is quick and has a bit of a kick when the water starts and stops. Love the no slam seat...though it shuts slowly.
Good thing I read on another site (that I bought it from) that the wax ring is NOT supplied. Everything else was pre-installed like the handle, chain, flapper, and fill valve.
I used small hack saw to cut off excess of the flange bolts.
Here's the end result...
Thanks again for the help guys.
I'm happily impressed.
TOTO Ultramax is AWESOME- Don't be afraid of Low-Flow toilets
This is the toilet for those who are afraid to switch to low-flow models because they perceive them as inefficient. They don't have to be. They just have to be well designed. Yet, I, too, was skeptical about changing, until one of our 20-year old toilets started leaking and the other required constant babying of the pull chain mechanism.
I came across the TOTO Ultramax toilet. I loved the sleek look and the soft-close cover, so I took the plunge and bought two - had them installed - and was so thrilled at the efficiency of their G-Max flush performance with low water usage, that I immediately went out and bought two more (for installation at my father's house). He's thrilled, too. They are worth the money. They're quiet, efficient, attractive, and comfortable. And they're only one piece, so cleaning is easy. This toilet flushes so well that residue is not building up from tainted bowl water. The bowl empties on every flush. Hard to get excited about toilets, but they are probably the most important fixture in your house when you think about it. Model is: MS854114S Color: 01 (White)
Is there a way to tame the Noisy Valve in Toto Ultramax?
Just finished (well, survived) a whole-house remodel, including installation of 3 Toto toilets, based largely on this site's recommendation (1-Ultramax, 2-Carlyle - 1.6 gpf, same flush mechanism). I am satisfied overall, but there is an annoying, screeching noise in all 3 of them during the flush cycle. After popping the lid to observe, I note that it happens as the tank starts to refill (the fill valve moves down and screeches) and then again when it's filled (the valve moves up and more screeches). We're talking LOUD - very audible outside the bathroom even with the fan turned on. Any suggestions for taming this noise would be appreciated. Thanks in advance!
