You must understand that he is a distributor and distributes to mostly factory reps and plumbing supply houses which then sell to their dealers and he has no experience with DIYers except here.
He loves Fleck because he can sell more of them simply because they have been on the market longer than Autotrol and Clack. He's here to counter everything I say and usually, as in his post above, he talks as if he is talking to other dealers.
He keeps saying Clack has had problems. I've sold a couple thousand and I had 2 bad circuit boards in 2004 just after starting to sell Clack. I can't recall any other problems or changes. Clack replaced those boards directly to my internet customers and paid the shipping. The customers were up and running in 3-4 days. Fleck is still weeks away from having good 7000 valves to their distributors... and the problem was with the valve body not a part on the valve as a circuit board is. That means the valve must be removed from the tank and then replaced and reprogrammed. And I suspect most of the customers will have bought from a local dealer so they will be waiting until the dealer can get around to them to do the job.
You could ask him what problems he has seen with Clack but I'm not sure he sells many, or has sold many and he surely has little to no field experience with them since he has said that he hasn't been in the field in years. And when he mentions his customers, remember he means his distributors, not you the end user.
He says he has worked with all the water softener companies... he means the national brand types and frankly, most DIYers have never heard of them but, local independent dealers such as me and hundreds of thousands others sell factory stock valves and have never heard of him or his companies (one of which sells knock off versions of Fleck and Clack). National brand dealers usually sell proprietary versions. And my guess is that most of the valves he sells are to guys treating city water with little to no experience on private well water.
He suggests the Fleck 7000 but if you watch the video of it and replacing the seals, spacers and piston, and the watch his video of the Clack, ask yourself which would you rather work on as a DIYer. The 7000 has been on the market since early 2005.
He suggests the 5800 too. It is a redone Fleck 5000 that had serious problems way back when and then was changed to the Proflo and now into the 5800. The previous versions weren't very popular.
He mentions the WS1 CS and limited programming... it has preset programming that you or the dealer choose from and there are some IIRC, 70+ to chose from for a softener and something like 30+/- for a regenerated or backwash only filter. And it can be used on tanks from 6" to 21" diameter which is about a 7 cuft softener. And the programing is only in day to day simple English, no Greek like one or two cryptic letters plus a number or two like Fleck requires.Anyione you buy a softener with a Clack valve on should be able to sell you parts if you need them. Or you go to;
www.softenerparts.com
