You CAN, but it probably won't work for the sink drain, unless you use a "wall mounted" sink that you can hang about 42" to the rim of it. However, it will work if you interchange the sink and washer "trap" locations, but keep the piping the same
OK -that should be manageable. So it seems there is a way to do this - now I just have to gather up the courage to rip out all the iron pipes!
