I have a GE water softner that is not pulling brine from the tank. I have cleaned the nozzle and venturi assembly. Any suggestions on what to look for next?
Printable View
Loose fittings on the brine line
Put the unit into a brine draw cycle. Disconnect the brine line from the valve. If water is coming out, than you need a rotor seal kit and possible a rotor.
