Originally Posted by
ditttohead
The question is about the use of hydrogen peroxide, GAC tank size, capacity and flow, not about marketing claims for the Chinese Market or companies in Taiwan, lets try to keep on subject and not troll. Regarding hydrogen peroxide, what dilution do you plan on using? 7% has been the most common for water treatment. I have used both 35% and 50%, but dont attempt it. It is very dangerous to work with at those levels and not worth the hassle or the special handling. As I remeber, it is DOT hazzardous so shipping would also be a problem. 3% is probably to weak and might get annoying having to constantly add it to the system. Your idea of being able to switch to chlorine is valid, you may try it both ways. Either way is fine, Chlorine is usually preferred for very minor reasons, but if you are more comfortable with Hydrogen peroxide then definitely go for it. Let us know how it works out for you.
