Originally Posted by
Kent Leigh
Hi Dittohead, just picking up on your last comment regarding service flow rates on the GAC. Today I have assumed a 2 cu ft GAC would meet my needs, but with the chart you provided, that will give me a 6 GPM service flow rate. This should be adequate for normal use, but in the cases where i have a peak flow rate exceeding the 6 GPM, would i expect chlorine bleed? Again, assuming peak flow rates at 12 GPM (more like 7 GPM but sizing for future visitors or changes to the house that would increase our normal peak).
Going from a GAC at 2 cu. ft. to a 3 cu. ft. system is an expensive proposition (extra $2-300 up front costs).
On a side note, I had a local treatment company come out. Two installers came out (not the owner), which I'm very appreciative that they came out the day after Thanksgiving. They quoted me the following system: 2 * 2510, 1 CF carbon + 1 CF Softener, 18X33 brine well @ $2600. The system would set to cycle twice a week at 12 lbs per cycle. When I challenged them on the size of the unit and that I wanted to go with a lower salt efficiency system, they basically told me regen at 6.5 lbs wouldn't regenerate the resin sufficiently. It was such a poor presentation and representation, I didn't bother getting into the math and going over additional specs and price.
