Originally Posted by
bookemdanno
A sufficient amount of H2O2 added to the OUTLET of a water heater and allowed to sit there overnight is much safer than turning up the heat. If you first flush off the bottom for several minutes, you will remove some of sediment that the bacteria can thrive in. This will solve the rotten egg odor 95% of the time and you won't void the water heater warranty by removing the anode rod (which rarely works). Hydrogen peroxide kills faster than bleach and when it breaks down, the second oxygen molecule comes off becoming water.
