Rainbird solenoid help please, it says "manual 1/4 turn On/Off
I think my solenoid is bad, I unscrewed and took it off of the valve.
I turned on the controller and walked back to the valve and just heard it buzzing.
I tried to clean the blue screen and it just fell apart in my hand.
I'm getting a new solenoid but what does the 1/4 manual on/off mean.
Don't I just screw it in all the way until it stops and wire it up.
Or does unscrewing it 1/4 turn turn it on somehow.
I tapped it on the ground and the round metal piece popped off, I then turned on the controller again and walked back and the metal rod was lying on the ground. Does putting power to it push the rod out?
I also think my Hunter EC controller is bad. I was trying to program it and it was 8:58pm and the timer said 8:98. And when trying to set the days it should show 1-7 but it was only showing 1-6. Any ideas ?
I tried to reset but the screen went blank when I pushed reset but everything came back to the same when I let go of the button. It kept the same programs.
