Is there a list somewhere of water spot sizes? Looking for a good performing, reliable, elongated gravity flush ADA model with the deepest and widest water spot.
Printable View
I know Toto lists water spot (Toto lists it as "Water Surface") on each toilet.
Form the Toto web site ( http://www.totousa.com/ ) Select a toilet, click on the "Downloads & Resources" tab, click on "Spec Sheet", click on models listed, located on the second page is the Water Surface size.
I don't know of an easy way to find water spot size in a more efficient manner.
I will at least tell you about some Totos you should consider. All the Totos I list meet your criteria for ADA (or "Universal") height, and are: (a) Reliable; (b)gravity toilets with (c) a GREAT flush.
The original Drake: CST744SL: ADA Height, 1.6gpf, Water Spot 10 3/8" x 8 1/4"
The Eco Drake: CST744EL: ADA Height, 1.28 gpf, Water Spot 10 3/8" x 8 1/4"
Drake II: CST454CEFG: Universal Height, 1.28 gpf, Water Spot 7 1/8" x 9 1/8"
Drake II 1G: CST454CUFG: Universal Height, 1.0 gpf, Water Spot Size not yet available (different-looking tank and trip lever from the standard Drake II)
Ultramax II: MS604114CEFG: One-piece toilet, Universal Height, 1.28 gpf, Water Spot 7 1/8" x 9 1/8"
Original Ultramax: MS854114SL: One-piece toilet, ADA Height, 1.6 gpf, Water Spot 10 5/16 x 8 1/4
Eco Original Utramax: MS854114EL: One-piece toilet, ADA Height, 1.28 gpf, Water Spot 10 1/4 x 8 1/4
Hope this helps.
Thanks. Is Toto the only mfr that lists water spots?
Thanks and I apologize if I seemed ungrateful. I've heard lots of good things about Toto over the years (I'm a remodeler). Problem is no Toto dealers in my area, so I'm left with American Standard and Kohler. Kohler's Highline Classic 14799-0 has a 11-3/8 x 8 water spot, which seems to be at least as good as any you listed. I'm also interested in American Standard's 710FA.101.020, but can't find any specs on their website.
I have to wonder why the water surface area is of concern and can only surmise it is to keep streaks below the water line. If so, one must also ascertain the location relative to the plumb line of the dump.
That's half of it - the other is odor control. This is getting too technical!
Didn't mean to seem crabby.
Toto is based in Georgia. Try here for places that carry them: http://www.totousa.com/Default.aspx?tabid=185 Also online sources available if nobody in your area. CST744S or CST744E are going to be available at a price close to that AS you are looking at.
The AS you mentioned -- is this a Lowe's only item (the "Saver" series)? I can't match the Lowe's item to a specific model on the AS web site. Good luck on getting good quality from AS at a big box, so I would call this a no-go. (Lots of info on this site about quality issues with AS toilets.)
Also, for what it's worth, depth is important too, in a water spot. There's a limit to how many litres the water spot can be and still keep the flush cycle (which includes the refill in its measurement) at the specified amount. So wide and shallow may not cover the waste, if you know what I mean. I'm not aware of anyone who gives the spec on the liquid volume of the waterspot.
The quick availability of replacement parts is also a concern.
NOW we are talking turkey! Bottom line is that Toto uses straightforward, non-proprietary parts made in large part by Korky here in the US and for which factory-authorized Korky replacement parts are available at any Lowe's and many local hardware stores.
Korky "Fits Toto" Red Flapper at Lowe's: Click Here
Korky 528MP Fill Valve at Lowe's, functionally-identical to the new Toto Universal Replacement Fill Valve that Korky manufactures for Toto and which Toto sells directly: Click Here
So, now and for the forseeable future, you will have no problem getting replacement parts easily and locally, or by mail order from Lowe's at an affordable price. Toto also has excellent customer service; if you call them with an issue, they are in Georgia, are very nice, and often will just send you a part free even if they don't have to, just to keep you as a happy customer.
