Originally Posted by
cgarai
Well thank you all for so much input.
I looked into salt dosage vs residual hardness leakage and found the link to the Purolite C100E resin. Looks like there is some leakage, but at least not much until you get to really low salt dosages.
As for the water heater, I read the warranty closer and they say this about water quality:
"WATER CHEMISTRY REQUIREMENTS – Sodium less than 20mGL.
Water pH between 6.0 and 8.0.
Hardness less than 7 grains.
Chlorine concentration less than 100 ppm."
I can see right away that I can't use sodium chloride. Also, here it states less than 7 gr/gal hardness, so reblending is not required. My pH however is right at the upper limit.
As far as my system, I think a 1 cuft system dosed at in the 5-6#/cuft will give adequate performance. Yes there are enough bathrooms and fixtures to exceed SFR of 9gpm. It won't happen often. If the guest bath starts getting used a lot then I can relatively inexpensively upgrade the tank. My concern here is more that I will have the metered regen being over ridden because we don't use enough water in 8 days.
I suppose an alternative would be to buy a bigger resin tank, but only load it with 1 cuft of resin and program the controller accordingly. If it turns out I need more capacity, all I have to do is add resin and reprogram. Does this make sense or is there a pitfall I haven't considered?
On another topic, which is likely to reveal a high level of ignorance: Does the rinse water from the regen cycle contain significant chlorine in it? Could it be dumped in a pool as part of the chlorine dose? Obviously it will have a significant amount of calcium in it, but I'm not sure how much in the context of a pool.
Chris
