Hardwire to dishwasher
I guess my question is more of an electrical question, sorry: I've replaced my old dishwasher with a new one. The old one was hardwired and the new one has a plug. What do I do with the old hardwire? Do I trim it, cap it, take it off the circuit entirely? As of now it's capped and shoved behind the new one but that's probably not the right thing to do. Any advice would be great! Thanks!
The cable should be removed back to the junction box which it originates from.
Why not just connect the hard wire to a outlet and plug the dishwasher into it?
John
THanks John and cacher_chick. John, I think you are right in that I should use the existing hardwire. It's safer.
Hard wiring a DW makes no sense. If it did, we'd hard wire electric ranges, and clothes dryers. Simply put an outlet box in the wall behind the DW, run the present wiring into it and install a socket. It you ever need to remove the DW for repair or replacement, this will greatly simplify the process. You will want to leave enough wire on the DW to allow it to slide out for servicing and still be connected. Same with the water line and drain. There's plenty of space under the DW to have the extra wire and water line.
