Submersible Pump in Above-ground Pool
Application: Dedicated Submersible Pump (separate from the pool filter pump) to provide water circulation through roof-mounted solar collector
Pool: 3000-gallon swim-in-place, metal-tube frame with vinyl liner (all equipment and metal components bonded). Circulation pump and heater fed by 30-amp, double-pole GFCI breaker
Submersible Pump: 1/6 HP, 6-amp, 120VAC, placed directly into pool.
Submersible Pump Circuit: Dedicated GFCI Duplex receptacle.
Monitoring: Weekly testing of GFCI receptacle.
Question: Does the above system provide adequate protection for swimmers in the event of submersible pump failure?
