Two questions re: 75 gallon WH replacement
I have to replace a 10-year-old 75 gallon WH that's leaking and would like some "expert advice" on two things:
1. If I have relatively easy access to the heater, could installation be a DIY job for one person? I've replaced a 40 gallon WH before by myself but I have no idea how much a 75 gallon WH weighs!
2. Is the Sears unit I've picked out a top choice for a replacement: http://www.sears.com/shc/s/p_10153_1...3176000P?mv=rr? It's got two magnesium anodes, 81 gph recovery at 90 degree rise, a 12 year limited warranty on parts and tank and is selling for $850. I'm going to be in the house for a long time and want a reliable unit. But it doesn't get a lot of use, since my wife and I are empty-nesters with occasional guests. It's sized mostly to enable my wife to take a bath in her large soaking tub.
Thanks for any advice you can give me!
Bob
what planet do you live on???
Quote:
Originally Posted by
Montalvo
Thanks for the prompt reply, Dana. I HAVE been working out and I AM probably as crazy as you when it comes to doing things myself. But hearing what this puppy weighs, I think I'll let the pros handle it. They'll pull a permit on it, cart the old one away and stand behind any problems that arise, too. What with tax, permit, etc., the installation will add about $450.
the sears units are basically junk..
it will be installed by sub contractors for sears....
the water heater will cost you about 790
the installation sounds dog dirt cheap...
and I would not trust them....
you ought to look into a Rheem pro or
a bradford white before you are stuck with
that pos..
Listen to what HJ has to say about this....
IF most heaters start to leak during the warranty period, you could call me and I would come and replace the water heater. If a Sears heater leaks, you MUST call them so they can inspect it first, and who knows how long that woud take, and then they have to deliver the heater, again not knowing how fast it would be. Then I, or someone else, could install it. In the meantime you are living with cold water only. As a side issue, but was disconcerting to one my customers who bought the house because it had a Sears Lifetime water heater, the heater is registered to YOU, and you only. If the house is sold the new owner has NO warranty regardless of how new the water heater, or what its warranty period, is.
Mark is too harsh and too blunt....
where-as HJ is much more diplomatic .and is 100% correct....
Like he has stated, if you have a Sears water heater leaking, they dont trust you to know your thumb from your ass, and want to send out a Sears repair man to "inspect" the heater to be sure it is leaking...
this usually cost $115.00 and they will come out to your home sometime between the hours of 8am and 5.pm.
YES, they do charge you for this call... aint that nice of them??.
Its really no big deal, all you have to do is take the day off work and wait on the Sears guy. When he shows up , he will verify that your heater is leaking , (which you already knew because it totally flooded your home) oops..... there goes my sarcasam again.....
then he will take your money and set you up with an appointment sometime over the next few days or weeks for one of their ....sub-contractors-- low end --underpaid installers ....to come out to install a new pro-rated water heater..
This also will happen between the hours of 8 and 5. and this willl also cost you another installation charge.......
:p
all this is well worth the big dollars you save initially going with a low end , crappy sears water heater..... oops, my bad again.....
LET THE BUYER BEWARE
here is a link to some of their complaints over the past years....http://baheyeldin.com/technology-in-...er-heater.html
oops, excuse me ..
I am getting too harsh and carried
away with myself,,,, again....
dont want to hurt anyones feelings.:rolleyes:
